Change Computers
Old Oct 27, 2003 | 10:05 AM
dead-woman-walk's Avatar
Car: 1984 CAMARO
Engine: v6
Transmission: automatic
Change Computers
I HAVE A 89 RS CAMARO THAT USES VAT KEY. BUT OWNER BEFORE ME TOOK THE STEERING COLUME OUT AND PUT ONE IN THAT DON'T USE VAT KEYS. MY QUESTION IS CAN I TAKE A COMPUTER OUT OF A EARLIER MODEL LIKE 84 AND PUT IT IN MY SO I CAN USE REGUAL KEY INSTEAD OF VAT KEY?
Old Oct 27, 2003 | 12:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Are you able to start the car and run it like it is now?
PS, all caps in your post is considered shouting.
The Trickster!!!!!!!!!!
Old Oct 27, 2003 | 12:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can just bypass the VATS system....
no need for a new ECM...
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
no, you can't use a different computer. TBI was never offered in thirdgens in the pre-VATS era. What's the big deal with using a VATS key anyway?
If you want to get rid of it that badly, do a search on VATS and you should find plenty of removal/bypass info.
Old Oct 27, 2003 | 01:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
unless you want to count the crossfire system......
Old Oct 27, 2003 | 01:12 PM
Car: 1984 CAMARO
Engine: v6
no it keeps comiing up about secutiy
Old Oct 27, 2003 | 01:27 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Ok dead-woman-walk,
Search back through the electronics forum for about the last three weeks and you will find where myself and several other members of this board have posted responses to other members who have a problem with VATS.
Old Oct 27, 2003 | 01:41 PM
Car: 1984 CAMARO
Engine: v6
what is the cross-fire?
Old Oct 27, 2003 | 01:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol
somthing you dont want.
its a older TBI system that 82 and 83 cars got... it was 2 TBIs that ran on a special manifold that looked a lil like the old carbed crossram manifold...
its had its fair share of probs.... and its not what you're looking for... i was just giving him a hard time.. lol
Old Oct 27, 2003 | 01:51 PM
Car: 1984 CAMARO
Engine: v6
is there a way just to diconnect it without buying anything just so i can see if the engine starts then like i said the steering colume had been change before me and i don't know how to do all that stuff you all talk about
Old Oct 27, 2003 | 01:57 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
well, we can help you with specific questions..... im assuming you have your VATS key, but when they replaced the column, the column didnt have vats correct?
if so, you can use a multimeter to get the value that your key is, goto a electronics parts store, get some resistors, and jumper your VATS wires with the proper reistance.
that will let the car start no prob.... you could also just replace they key cyl with a VATS one, and run the wires down the column...
after almost getting my car stolen, and having it saved only by VATS, i wouldnt get rid of it
Old Oct 27, 2003 | 02:02 PM
Car: 1984 CAMARO
Engine: v6
i don't have key or anything
Old Oct 27, 2003 | 02:07 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you mean, in the entire time you've had this car, you have never seen it run?
you dont have your OLDKEY at all?
Old Oct 27, 2003 | 02:13 PM
Car: 1984 CAMARO
Engine: v6
i only had it about a week so no and i know nothing about all this computer stuff but the guy i got it from had the key but i don't know he he still has it or not
Old Oct 27, 2003 | 02:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
try to get it from him. i'll save you ALOT of work.
Old Oct 27, 2003 | 02:25 PM
Car: 1984 CAMARO
Engine: v6
if i get the key then do i just buy resistor and bypass? i do i know which one to buy how to i check the key value
Old Oct 27, 2003 | 02:31 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
on the key there will be 2 contacts... touch a multimeter set to ohms to the contacts...... thats the resistance of the key's pellet...
then find a resistor (or several resistors together) that match that number...
go under the dash on the drivers side and find where the plug for the vats wires that is suppost to goto the column is...
plug in the correct resistors between the 2 wires..
the car should start when you turn the key now.
Old Oct 27, 2003 | 02:32 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
holy double post batman!
Old Oct 27, 2003 | 04:04 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
How was the original owner driving the car? For all this trouble, I hope you got the car for an extremely low price!!!!
The Trickster!!!!!!!!!!!!!!!
Old Nov 3, 2003 | 05:15 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Ya..i would say to take it to someone who knows how to do this stuff. Maybe a friend or friends father. Im not sure what vats is. Is it the anti-theft mechanism built in newer 3rd gen f-bodies? It sounds like it. Anyway good luck. I hope everything works out for you!
nate
eightsixseven
Dec 16, 2024 01:50 PM
z28addict8490
Sep 5, 2015 03:56 PM
86IROC112
Aug 21, 2015 07:20 PM
perZ
Aug 15, 2015 01:17 PM
Thirim
Aug 9, 2015 06:19 PM
