Need help please!
Old Nov 6, 2003 | 12:11 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
Need help please!
I was moving my car into my garage yesterday and everything was working fine. Then i was leaving to go see Matrix: Revolutions last night and i noticed that my gauges arent lighting up, my headlight would pop-up but not go down, and my tail lights would not illuminate unless i stepped on the brakes. also my side markers dont light up unless i turn my turn signal on. also, my last fog light wont work now either. someone please help!
Old Nov 6, 2003 | 12:14 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Did u check for burnt fuses?
check fuses and the bulbs..
Old Nov 6, 2003 | 12:28 PM
Syxx613's Avatar
ok i checked fuses and the one for tail was burnt bad so i replaced it and as soon as i stuck it in my lights finally went down. so then i tried to turn my gauge lights and side marker lights on and all and the fuse blew right away. it did this 3 times! what could be causing that?
