high beam question....
Old Nov 3, 2003 | 11:38 AM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
the high beams in my sc do not come on for some reason, yet the indicator comes on when i hit the switch.
thinking the headlights might be bad, i replaced them with the cool blues from my z28 that i'm putting in storage.... and it still does not turn the high beams on..
before i dig out my factory service manual, i wanted to ask here, is there anything in particular i should know about how the high beams work?
car in question is an 84 camaro.
Old Nov 3, 2003 | 08:09 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Check for voltage at the plug of one of the inboard high-only bulbs. The dash light coming on means the switch is functioning properly. Unless there have relays added in for the headlight circuit, you may have a broken feed wire.
Pete
Old Nov 3, 2003 | 08:55 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Pete
that's what threw me off, the indicator still coming on. i'll check the plugs. i guess i really need a multimeter. i should expect to see 12 volts at that particular plug, correct?
thanks a bunch pete
Old Nov 3, 2003 | 09:39 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
yes, 12v.
Sometimes those connectors are a PITA - make sure you've cleaned the contacts pretty well and used a good dielectric grease.
Old Nov 6, 2003 | 06:00 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
i'll have to check that out, i also want to double check the wiring as well
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
