the infamous inaccurate tach....
Old Nov 6, 2003 | 02:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
so far, this is really all ive found:
Originally posted by Morley
Check this thread.
https://www.thirdgen.org/techbb2/sho...hreadid=109181
It describes how to make a V6 tach work on a V8 engine.
I gave a pretty good description of where the capacitor is on the tach on this thread. https://www.thirdgen.org/techbb2/sho...hreadid=114057
Look at my second post on that thread, the first one I was a little off in the position of the capacitor.
now that was suppost to fix the cap that changes it from V6 to V8....
my questions are:
  • what is the part that wears out over time? is it that cap?
  • is my 91 tach the same circuit as the older tachs?
  • if it is a cap or resistor that wears out, can i replace it with a variable one, then use a scanner program to "tune" it to work better?
i really like the looks of my stock tach, and im not adding a aftermarket one to my car.... it would be nice if it was more accurate though..
Old Nov 6, 2003 | 06:09 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
I think the capacitor might be the problem. My TV repair guy agrees for what that's worth. I have ordered one after I install it I will let you know. Cross your fingers.If it doesn't work I'll be out $.57 and we will all be a little wiser.
Old Nov 6, 2003 | 07:31 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
My tach is totally off. In my GTA that has the digital dash As soon as it reaches 3000 rpms it just jumps up to 6000. Have any ideas for that??
toones
Jan 6, 2016 06:00 PM
86IROC112
Sep 11, 2015 04:04 PM
Matty377
Jun 26, 2002 08:38 PM
Confuzed1
Carburetors
Jan 8, 2002 03:40 PM
korbin
Carburetors
Oct 1, 2001 10:02 AM
