gauge,ac control,and gear shift lights dont work?
Old Nov 13, 2003 | 06:05 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
My gauge ac control and gear shift light dont work I was hooking up the gear shift light I spliced the wires together and put butt connectors it was a green and a black wire after I did that my gauge light and ac and the gear light all died I checked the fuses but none of them are blown so what could I have done wrong??
Old Nov 13, 2003 | 09:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
All the gauge/hvac/shifter lighting is powered by the light switch.
Power is ultimately recieved from the light switch for the marker lamps via 'tail' fuse (20amp). From there (output power to the maker lamps), it is split within the light switch and also powers the gauge lights which goes from the switch->gages fuse(5A)->gauge/hvac/shifter lights.
If the fuses are good then there is a problem with the switch or the circuit leading from it.
Ghettobird52
Jul 5, 2024 11:18 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
