89 TTA Wiring Harness
Old Nov 17, 2003 | 07:21 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Anyone know who has one for sale or knows how to make one?
Old Nov 17, 2003 | 07:31 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
If they are as hard to find as a regular Speed Density harness, all I can do is wish you good luck
Old Nov 17, 2003 | 08:55 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I have found some used ones and Casper Electronics sells reproductions ones (For 750+). So I am more looking for a used set.
Old Nov 17, 2003 | 10:28 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: 89 TTA Wiring Harness
Find an 87 FWD with a 3.8 in it.
It has the right ECM and all the sensors BUT the MAF are correct. Meaning you'll have all the right colors of wiring, and correct sensor connectors.
Then just cut and splice as necessary.
Then get the harness out of some later V6, to get extra lenghts of wire, and the later injector connectors. The earlier ones work OK, but the later are more moisture proof.
In the past I've found GN harnesses for $150, but they are few and far between.
Old Nov 19, 2003 | 03:52 PM
Mako's Avatar
Car: 89 GTA
Engine: 3.8
Transmission: 200-4r
Part number 1206932. Still available from GMpartsdirect.
Hey Grumpy: Is the firewall C100 connector pinout the same on the FWD harness? And also can I use the newer model FWD injector harness when I upgrade to 009s? Plug and play?
Old Nov 19, 2003 | 10:19 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The ecm/efi harness is a dedicated harness, with just tie in's to the behind dash harness. While it goes thru a bulkhead, it's not actually a connector. I don't know what the connector C100 is.
There are several different injector harnesses, all with different connectors, weither those particular two interchange or not I can't tell you. You can use any port injector with the oem harness, it's in some cars that need the power supply wire redone when using Peak and Hold injectors, ie low impedance.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
