ALDL connector source?
Old Nov 21, 2003 | 09:49 PM
David Trimble's Avatar
Does anyone know of a place that sells these connectors? I need a male ALDL connector that would plug into the port on my '84 T/A......
Thanks!
Old Nov 22, 2003 | 03:18 PM
onebinky's Avatar
I don't remember what website my dad found one at, but they were pretty pricey. They wanted something like $40 for just the female connector. I'll see if I can get the name of the site tonight for you.
Matt
EDIT: on my 85,87, and 92, they all had the male end built into the car. Are you sure it's not the female end you're looking for?
Old Nov 23, 2003 | 12:51 PM
You might be right- it could be a female connector that I'm needing. Basically I need it to build a ALDL to 9-pin PC serial cable. But if you can find out what website it was at I'd appreciate it!
Old Nov 24, 2003 | 04:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The Auto X-ray cable available from Summit/Jegs is the only source that I know of, $25 IIRC. If you only need it for your car(s) then paralleling in a DB9 with the ALDL connector is known to work.
RBob.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
greenyone
Sep 8, 2015 08:41 PM
