My Power Antenna Is Alive!!!
Old Nov 25, 2003 | 12:35 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
I've had the car since 2000 and the power antenna has NEVER worked! Suddenly today, I go outside and my car is making a funny, motorized noise. It's coming from the antenna. It still doesn't move, but it runs all the time, even when the car is off. I had to disconnect the battery to stop it. I'll probably try to look at it this weekend when I get time. Any ideas? I can't understand why it would start making noise after 3 years!
Old Nov 26, 2003 | 01:29 AM
GTA4ME's Avatar
What, nobody has any suggestions??? Did I stump the everybody with this one?
Old Nov 26, 2003 | 08:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I believe you should have a relay under the pass side of the dash (if need be, try the wiring from the radio to it). Unhook the relay and you should be fine.
JamesC
Old Nov 26, 2003 | 09:14 AM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
The plastic "cable" that connects the motor to the antenna and makes it go up and down is broke. It's relatively cheap/easy to replace.
MCM
Old Nov 26, 2003 | 09:16 AM
GTA4ME's Avatar
So that would cause it to run constantly, even with the car off???
Old Nov 26, 2003 | 09:21 AM
Car: '82 Trans Am
Transmission: TH475
Yes. With the cable broke, it doesn't know where the antenna is, so it keeps trying to retract it, even after you shut the key off. When the key is on (and radio), it keeps trying to extend it. Either way, it runs ALL the time when the cable breaks.
MCM
Old Nov 26, 2003 | 02:11 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
MCM
Any info on how to make this fix? Thanks!
Old Nov 26, 2003 | 02:44 PM
GTA4ME's Avatar
I'm not even going to have a chance to look at it until this weekend.
Old Nov 26, 2003 | 05:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you do a search you'll find the P/N for the repair kit, it comes with all the directions you'll need.
Vintageracer
Jan 10, 2020 05:33 PM
Slush92RS
Sep 2, 2015 08:56 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
