My 92's 3rd brake light keeps burning out!!!!
Old Nov 28, 2003 | 01:21 AM
5speedrs305's Avatar
Since the car was BRAND NEW the 3rd brake light kept burning out, I have changed it like 5 times. The last 5 years or so I haven;t changed it because all it will do is work for a month or so and burn out again. Can anyone help me out??? I am thinking the bulb might get to hot and then burn out, Is there a bulb that I can stick in there that might not heat up so hot? anyone have this problem?
Old Nov 28, 2003 | 06:37 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
When you install the bulbs do you use your bare fingers???
These are halogen bulbs and the oil from your skin causes hot spots, resulting in burnsout. Just a thought, I have had only3 or 4 failures in 16yrs.
Old Dec 5, 2003 | 05:30 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Switch to LED's lamps! Using O-rings to slip them in the holes nad the original electrical strip to power them, worked pretty well on my car and the LEDs are a fraction of the cost of those weird little bulbs... I'm working on a new version with more lights and will do a photo-guided thread soon!
Old Dec 5, 2003 | 07:06 PM
What are LED's lamps! Plus what do you mean use O-rings? could you explain alittle more and mabe show me some pics.
eightsixseven
Dec 16, 2024 01:50 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
