painless wiring?
Old Nov 30, 2003 | 06:26 PM
Kandied91z's Avatar
painless wiring?
i have so many accessories that the underside by my fuse pannel is a mess. anyone have experience with adding fuse pannels to a car.
i'd like to add one to the rear and the passenger side so that i could clean up the wiring.......what would i need to do to add one?
Old Dec 1, 2003 | 10:55 PM
Kandied91z's Avatar
nobody has added a secondary fuse box?
Old Dec 2, 2003 | 01:59 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
basically run a power wire direct from the battery over to the pass side in kinda the same spot as the factory one on the drivers side. Then just hook up your accessories. IIRC I didn't hook up a second fuse block but rather a distribution block for five more B+ sources on my camaro. Fuel pump, fan, Fuel pump #2, ignition, and I think the fifth one might be open still. But it's fairly easy to do and shouldn't be much of a problem.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
Ducati900ss
Sep 2, 2015 09:05 AM
stalkier
Aug 21, 2015 01:54 AM
squiggy2
Aug 9, 2015 09:30 PM
