Working on airbag steering shaft?
Old Dec 6, 2003 | 03:57 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I need to know if there are any precations to working on a airbag equiped car 90 gta. I need to get the shaft out to reroute my brake lines and install my headers and I'm a little worried about doing this because I've never messed with an airbag before. I already disconnected both battery terminals.
Old Dec 6, 2003 | 05:11 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
also pull the airbag fuse in the fuse box, since the air bag system has a backup battery, in the event that the battery is destroyed it still can be deployed, also disconnect the airbag assurance connector, under the column, it is in bright yellow wiring
Old Dec 7, 2003 | 03:45 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
yeah all you need to do is disconnect the batt, take the SIR fuse out, disconnect the yellow airbag wire under the dash. in that order.
Old Dec 7, 2003 | 05:33 PM
slayer2000's Avatar
Car: 1990 GTA
Thanks guys. Just didn't want to blow my airbag because of a mistake.
Vintageracer
Jan 10, 2020 05:33 PM
Streetstuff
Sep 7, 2015 09:23 AM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
MENINBLK
Aug 5, 2015 11:58 PM
