tach reading low, or is it?
Old Dec 7, 2003 | 11:45 PM
86birdv6's Avatar
i'm in the process of swapping to a cluster with the gauge pack, from the dummy light cluster in my firebird. just took it for the first rip tonight, but the tach didn't seem to be working right.
the idle red correct at 900rpm, and it also seemed to be pretty correct with me at 2100rpm at about 110kph. the issue is that when i would mash the gas and run the car up to what feels like what would be redline, the tach will only go as far as 4000rpm. it also climbs very slowly even though i can hear the engine picking up the revs faster.
the car is an 86 v6, and the other cluster is out of a wrecked 86 v6.
does this sound like a common problem, or do you figure the tach is infact reading accurate? is there any way for me to test this?
Old Dec 7, 2003 | 11:59 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
The stock gauges arent very accurate to begin with.
Old Dec 8, 2003 | 10:46 PM
86birdv6's Avatar
maybe so, but not getting within almost 2k of redline?
is there a way to recalibrate the tach at all that anyone knows of, or any other remedies?
Old Dec 8, 2003 | 10:55 PM
Kandied91z's Avatar
you could send the tach out for a rebuild but it would be easier and better to get a good guage. mine is roughly 300 off so i plan to install an autometer some day.
Old Mar 16, 2004 | 04:57 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
bringing this back as after a cluster swap, i have the same problem, above 2500 rpms it rises real slow and sometimes just sticks at an rpm until i touch the needle. The needle moves all the way around its clocking smoothly when i move it by hand. Could a weak electrical connection be the problem or is my tach bad?
Old Mar 16, 2004 | 08:56 PM
flowmasterchevy's Avatar
Car: '91 RS, F41
Transmission: WC T5
mine is way off, it reads about 4500 at idle and shoots over past 7k at what i think is about 2500, can you fix these tachs or is it hopeless? should i just buy an aftermarket?
eightsixseven
Dec 16, 2024 01:50 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
Regal105
Aug 23, 2015 03:45 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
