Correct Battery Specs?
Old Dec 8, 2003 | 01:24 PM
FocusGhia's Avatar
Car: 88 Camaro IROC T-Top - Gunmetal Grey
Engine: 305 TPI V8
Hi, I have an 88 Camaro IROC 305 TPI and according to some gadget my local auto place has I need a new battery.
Problem is the battery says it's rated at 735CCA and 100 minutes
The biggest battery they sell is 650CCA but these figures are all way more than my friends 99 Z28 has on its battery.
I figure the previous owner replaced the battery with this much bigger one.
Anyone know what the correct battery specs are?
Being in the UK I can't go buy a part number, I need the CCA rating etc...
Old Dec 8, 2003 | 02:30 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Hey Focus,
I have a Firebird, and the biggest battery that will fit is a 55Ah one, it does the job well!
Only be sure to buy a good brand!(I use only Varta)
B.t.w. there are special connectors available to fit a battery with round top poles, makes the search a lot easier.
Old Dec 9, 2003 | 11:21 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The OE battery is a Delco 72A12, newer number depending on warranty time is a 75A60, or 75A72. It is a 75 amp/hr battery. That means it will deliver fully charged 75 amps for one hour before it becomes technically discharged. CCA ratings vary from manufacturer to manufacturer, many times I think they overrate them. 500 CCA minimum should be fine for all but the most extreme situations. Up to you how high you want to go.
morrow
Jan 13, 2024 12:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
GTAman
Sep 21, 2015 09:57 AM
BAMiller
Sep 14, 2015 06:38 PM
