door locks twitching!?
Old Dec 10, 2003 | 04:23 AM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
Ok, I have had this problem a few times before, when I first got the camaro in late January of this year. This is the first time it has happened this winter so far, it's in the mid 40's outside, I think.
I turn the car on, and the door locks start twitching on and off, on and off. When I shut the car off, then keep twitching. I'm not sure how long they twitch for, and there isn't really anything I can do to stop them.
I have a feeling that it has something to do with the cold, as tonight (2:30 AM) it feels the coldest it has been this winter, and this is the first time this winter the locks have done this.
Electric locks, BTW
Any one else experienced this? what should I do?
Old Dec 10, 2003 | 08:49 AM
holov1's Avatar
Car: 89 formula 350
Engine: L98(350)
check to see if one of the switches isn't stuck in the panel it that's not it then unplug the doorlock relay could be a bad switch or relay then look for broken wires somewhere possibly in the door boots(rubber part between door and cowl where the wires come thru.)
Old Dec 10, 2003 | 09:43 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
my experiance is, dirty water gets in the switch or relays, and that makes them go crazy.
Old Dec 10, 2003 | 12:58 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
We don't ever use the door locks by hand, I have an alarm. (they twitched before the alarm as well)
I havn't driven through water laterly, I live in Phoenix. But I have driven through a bit of water a while back, but nothing major.
where is the switch relay? Can I just unplug them and clean them out? or do they need to be replaced?
Thanks a ton!
Old Dec 10, 2003 | 04:01 PM
holov1's Avatar
Car: 89 formula 350
Engine: L98(350)
the relay should be in the drivers kick panel you can unplugged it but then your door locks on your alarm will not work either. should try to replace the relay.
Old Dec 10, 2003 | 06:13 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
what is the kick panel?
Thanks!
Old Dec 10, 2003 | 06:53 PM
3gc's Avatar
3gc
Car: Z28
The Kick panel is the plastic panel next to your left foot when your sitting in your drivers seat. It's held in by three screws. Sometimes on carpeted ones it's hard to see the two screws on the side of it but they're there.
Also check to make sure the screw for the relay backet is tight and there is a good connection there. The relay gets its ground form that screw.
Old Dec 10, 2003 | 08:01 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
ahh, thanks!
Any reason why this would only happen when it's extremely cold out?
Old Dec 10, 2003 | 09:31 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
coupld only happen when its cold out because the little metal contacts in the relay have gotten closer together due to the contracting metal.
Old Dec 10, 2003 | 09:43 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
ahh, so that is possible? I wasn't sure if that could be it or not.
But anyway, thanks everyone, I'll replace that relay, but I'm not sure if it will get cold enough to test it again :-)
Old Jan 9, 2004 | 01:52 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
ok, I'm back from christmas vacation, and I finally got a chance to yank out the door lock relay, and I can't seem to find anywhere that carries it. Checker gave me some part numbers DR161C, R6003, and Ry-215 but these numbers don't ring up at anywhere like summit or jegs.
where can I find this? the numbers on the relay are 6051 and IEC 20191641
any help is appreciated!
Old Jan 9, 2004 | 09:06 PM
8Firebird8's Avatar
Car: '88 Firebird, '85 Trans Am
Engine: 2.8 V-6, 305
Transmission: Automatics in both
This may sound crazy, but check your battery terminals. If they're loose, it will cause your locks to go nuts.
Old Jan 9, 2004 | 11:37 PM
3gc's Avatar
3gc
Car: Z28
That relay might be a dealer only item. It would be worth a shot if you can't find it anywhere else.
Old Jan 10, 2004 | 01:31 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
aiight, I got the door lock relay on order from the chevy dealer, woot woot!
a friend of mine has a huge electric meter that does all kinds of things, he is gonna come over and help me find my electrical drain sometime soon.
I just hope it gets cold enough sometime to test the new relay when it comes in. otherwise, I gotta wait till next winter :-\
Old Jan 10, 2004 | 03:17 PM
3gc's Avatar
3gc
Car: Z28
Drive to another state to test it, it's plenty cold in New York right now
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
my86bird
Oct 23, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
