Melted Connector, Help!!!!
Old Dec 16, 2003 | 11:59 AM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
If you look at the pic I posted(which is not my car BTW) That connector on the red wire has completely meltd off!!!! Why is it doing this and what do I know to do to fix it????
Old Dec 17, 2003 | 01:34 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That connector is for either your AC/Heater blower motor or your underhood courtesy light and as for why it is melting. You might have a short somewhere in the system causing an overload.
The Trickster!!!!!!!!!!!!!!!
Old Dec 23, 2003 | 11:33 AM
Engine: Mild 350
Trickster, can I ut the melted part off and just splice in a section of wire after I find the short?
Old Dec 23, 2003 | 11:35 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you will follow that wire up into that wire sleeve, you will find that that wire is already spliced into another wire. This is how GM got around running so many wires. As I mentioned in my other post, that connector is either for the ac/heater blower motor or the underhood courtesy light. They are both powered from the same wire. By the right hand hood strut you should see a wire with a fuse holder containing a four amp fuse that is supposed to protect that connector. Check it. As far as splicing in a wire to replace that connector, it would be better to replace the connector.
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
wstephan96
Sep 25, 2015 04:28 PM
