3 wire heated o2 sensor
Old Dec 17, 2003 | 05:25 PM
87camaro kid's Avatar
Car: 1987 Z28
ok correct me if im wrong(this is how im guessing i can connect my sensor up cause i have no idea how to look at wiring digrames) ok so our origonal o2 sensor is just one wire and that one wire is connected to the ECM correct? so i can just connect the one wire on the new sensor for the ecm to that existing wire and the other 2 wires to the positive battery and the other wire to a ground on the chasis somewere. does that sound right sry if that was completly stupid but im trying
Old Dec 17, 2003 | 08:01 PM
85TransAm406's Avatar
Car: 1985 Trans Am
hook the extra + wire to a switched power and the other to a ground. Otherwise the O2 would be heated all the time, runnin down the battery. I did the heated 02 conversion in my camaro after the headers, worked great.
Old Dec 17, 2003 | 08:28 PM
Car: 1987 Z28
were would i hook the positive up to then?
thanx for ur help
Old Dec 17, 2003 | 11:51 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
thanx for ur help
hook it to on o the "ign" terminals in your fuse panel.
or, just connect it to the power source of something that you know is only on when the car is running.
-brian
Old Dec 18, 2003 | 09:41 AM
Car: 1987 Z28
thanx
meeklay812
Oct 1, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
