Speedometer/Odometer Cable???
Old Dec 20, 2003 | 05:36 PM
92CAMARORS305's Avatar
Car: 92 Camaro RS/07 GSXR1000
Engine: 305 - 5.0TBI
My speedometer and odometer just stopped working. I heard that the speedometer/odometer cable may be the problem but I can only find information on pre-90's camaros having these cables. I have a 92. Am I looking in the wrong place or are they controlled by something other than a cable after 90? If you could point me in the right direction(possibly a link that sells the part I need) that would be awesome.
Old Dec 22, 2003 | 07:01 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Your car has a VSS sender mounted at the transmission where the cable unit went on older models. Do you have a "service engine" light, normally when the VSS fails the ECM will throw a trouble code. If there is no code I would suspect the speedo unit itself.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
