Problems with door switches
Old Dec 22, 2003 | 11:54 AM
92HeritageZ28's Avatar
Car: 1992 Heritage Z28
Engine: 5.7l TPI
Transmission: A4
i have an alpine security/keyless entry system for my car. one day the display said i had a faulty door sensor and my dome light refused to turn off no matter what i did. i had to pull the bulb out to keep from running the battery down. i tried unhooking each of the door switches and messing with them, but nothing would turn off the light. is there anything besides the door switches that could cause this?
Old Dec 22, 2003 | 07:53 PM
Morley's Avatar
check all of your interior lights and the fuse for them.
Old Dec 22, 2003 | 11:15 PM
onebinky's Avatar
If the alarm has domelight supervision, the relay for it could be grounding out causing it to stay closed all the time, or the relay could be bad and it's stuck in the closed position. That would make the domelight illuminate constantly, and cause the alarm to ignore it also.
Old Dec 29, 2003 | 11:53 AM
Engine: 5.7l TPI
Transmission: A4
where do i find the domelight relay, and which relay is it?
Old Dec 29, 2003 | 09:32 PM
onebinky's Avatar
It all depends on where the alarm installer put it. It's not OE though, if that's what your wondering. It'll probably be a standard bosch type SPDT relay, that looks like a little rectangular box with 4 or 5 wires coming out of it.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
