speedometer question
Old Dec 22, 2003 | 06:11 PM
azraelpins's Avatar
Car: 87 trans am
Engine: 305 carb
Transmission: t5
i dont know how many times this question has arised but i cant find the answer in the search, sorry but here it is.
i have an 80 mph speedo in my car and i just bought a 140mph speedo, will i have to adjust anything so it will show the proper reading or should the new one configure itself? its not just an overlay but actual guages with the plugs. again, im sorry for asking a question that i know has popped up before.
Old Dec 22, 2003 | 11:18 PM
onebinky's Avatar
If you are just swapping the speedo, it's direct. If you are changing the entire gauge pod, get a schematic for the new pod year, and the old pod year and then compare the pinouts. They changed a bit throughout the years.
As far as calibration though, you shouldn't have to mess with that.
Old Dec 25, 2003 | 03:51 PM
azraelpins's Avatar
Car: 87 trans am
Engine: 305 carb
Transmission: t5
its not a speedometer from another year model but the same white faced gauges on hawks. will that one align correctly?
Old Dec 30, 2003 | 10:17 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
You should have no problem. I did a swap before on mine and it works fine.
Old Jan 20, 2004 | 09:26 PM
azraelpins's Avatar
Car: 87 trans am
Engine: 305 carb
Transmission: t5
ok, i did the swap and the calibration is way off, of course. i talked to my mechanic and hes talking about sending my cluster to somewhere in texas that can recalibrate the cluster to make the necessary adjustment. gm must have a part that does that because to my understanding there were t/a's made with 140mph speedometers.
anybody have feedback
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
