hooking up 84 camaro non a/c heater box...
Old Dec 29, 2003 | 01:00 PM
CamaroEFI's Avatar
i really need some info on how to wire up an 84 camaro NON a/c heater box up to my 91 camaro w/ a/c. i already took out all of the a/c equipment and bolted the "new" box in but i left the a/c wiring harness. ovbiously its not as easy as just plugging it up. i need to know which wires to splice and hook up to the prongs on the NON a/c box.
Old Dec 29, 2003 | 07:11 PM
MdFormula350's Avatar
i used this diagram
http://92b4crs.tripod.com/86wiring/dia-pics/60-0.jpg
with the other diagram and worked them together to get everything to work out.
Attached Thumbnails hooking up 84 camaro non a/c heater box...-heat2.jpg
Old Jan 3, 2004 | 03:48 AM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
I just did this with my 87 the other day..
The A/C model has a four speed blower and the heater has a three.
Heater has a three wire resistor
Orange wire=high fan speed
lt blue wire=med speed
yellow= low speed
A/C model has a four speed resistor:
orange:high fan speed
lt blue:med 2 speed
tan:med1 speed
yellow:low speed
I hope you have the heater style resistor and plug-in......
So you can cut off the heavy purple wire, unused yellow wire and relay and A/C resistor and splice oranges together, blues together, and yellow to tan.
So then when you turn on your fan the first low position (it has the little picture of a fan blade)on the controller will be "off" now, and the next three settings will be low, med, and Hi dont forget the ground wire and the radio noise suppresor
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
