seat belt light stays on,,82 model,z28
Old Jan 1, 2004 | 06:11 AM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
the seat belt light on the dash stays on ,,,,,even after all belts are inserted,,is this a timer ,,or does the buckle have a switch in it,,82,z/28
Old Jan 1, 2004 | 11:15 AM
Slick86's Avatar
Car: Pontica F-bird
Engine: 355
Transmission: 700-R4
I have this same problem.
Old Jan 1, 2004 | 01:08 PM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
No I dont think it has a buckle sensor or anything. Cuz it should go off in like 5 seconds or something. Id just unhook the bulb if I was you. That light is useless anyway.
Old Jan 1, 2004 | 04:09 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
There is a switch, originally in the left-hand side seat belt setup. I'm guessing that lukerene's car has been converted to right-hand drive(?) so it's hard to say how that was handled. However, the light should go out on it's own in 5-10 seconds after startup. It is controlled by a set of contacts inside the black or grey box located in the convenience center, which is located above the hush panel on the left side, near the center console. The convenience center also houses the hazard waring flasher, and the choke heater and horn relays. It may need replacing; it's the only one there with more than 3 contacts - it has maybe six or eight.
Pete
Old Jan 1, 2004 | 05:20 PM
lukerene's Avatar
thanks peter will do mate,,,i dont want to simply pull yhe bulb from the dash or the light globe,, i will get it sorted out ,properly,, aussie steve
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
Jae992
Aug 27, 2015 09:07 AM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
