wiring a motor
Old Jan 6, 2004 | 11:04 AM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
wiring a motor
i am switching mtors from a 2.8 multi port to a 5.7 carb and i was wondering how i should hook up my wires to the motor. they appear to be diff connectors, so would i splice the old ones and put the connecters i need on? do i get them at an auto parts store? which wires do i need hooked up
i searched for a sensor topic. and i couldnt find much so which sensors do i have to have hooked up.
Old Jan 6, 2004 | 11:33 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
There are not any sensors that you're going to need with the exception of your gage sending units. This will be your coolant temp and oil pressure gages. Aside from this, you are going to need to wire your electric fan to a relay and ground that relay open via a fan temperature switch in the passenger side head. You will need switched power for your coil, and of course the alternator and starter leads. A choking system may be necessary depening on your carb. You'll need to leave the climate control wiring intact. You will need to locate the tach wire and place it in the tach output on your vaccum advance distributor. There may be a tech article on this already somewhere...start doing some searching.
Old Jan 6, 2004 | 01:39 PM
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
im thinking about running a fan off the pulleys like the traditional v8s would run. would that be easier?
i am gettnig an electric choke carb
Old Jan 6, 2004 | 01:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no.. not any easier... but it will make it get really hot when you're idling in traffic and not much air is moving thru the radiator.... it'll also cost you horsepower..... and overall, is less efficent.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
355sbcTPI
Aug 19, 2015 04:38 PM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
