need help installing a tach on 84 Z
Old Jan 7, 2004 | 12:08 PM
CAMAROF41's Avatar
Car: 84 camaro z28 with F41 option ex-cop car
Engine: Carbed 305 v8
Hey guys i have a 84 305v8 carbed i'm adding a tach and i need the negative ground wire from the coil, but i dont have my hanes manua so i dont know which one it is, could some one give me a hand thanks alot.
dustin
Old Jan 7, 2004 | 12:12 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
let's see here......this is off my autometer tach with shift light wiring:
autometer wires.....
red
black
white
green
hook up to:
red.....12 volt positive ignition on source
black.....good engine ground....i ran mine to the battery for best signal
white......aux. light tap into any B+ signal when headlights are turned on
green......tach signal wire....this is the white one coming off the distributor.
hope this helps..
Old Jan 7, 2004 | 12:18 PM
CAMAROF41's Avatar
so its the white wire off the distributor? ok i got thanks alot man.
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
