possible to get a new gm wiring harness?
Old Jan 7, 2004 | 04:01 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
just like the topic says, is it possible to get a new wiring harness from gm, or anywhere that sells gm parts? i need the ecm harness that goes from the computer into the engine bay, as mine is quite fried. finding a used one that matches my car exactly has been a nightmare, and i would really rather not cob something up with bits and pieces of different harnesses. btw, the car is an 85 trans am, L69, 5 speed with a/c. if you can't get a gm harness, does any aftermarket company make one that would work specifically for my car?
Old Jan 7, 2004 | 06:20 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
Re: possible to get a new gm wiring harness?
Painless Wiring, although most catalogs don't specify L69/LG4 (Carbed) applications.... they should in fact have one. If you go through GM, I'm sure they have what you need.... but be prepared to pay top dollar with them.
Old Jan 8, 2004 | 11:23 AM
Diabolical's Avatar
Engine: 305HO L69
Re: Re: possible to get a new gm wiring harness?
I contacted Painless Wiring a while ago, they told me that they had something that would work and gave me the number for one of their dealers. When I called them, they said they don't make anything specific. He said painless was probably talking about a universal harness that might possibly fit with a lot of work.
Old Jan 10, 2004 | 04:13 PM
Diabolical's Avatar
Engine: 305HO L69
anyone have any experience using these wiring harnesses?
Old Jan 11, 2004 | 12:59 PM
3gc's Avatar
3gc
Car: Z28
Might want to try Howell-efi.com. And maybe take this as the perfect opourtunity to convert to TPI or a non computer controled carb.
Old Jan 12, 2004 | 12:26 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The Painless harness is designed to be universal. It's really designed for engine swap applications (TPI engine in a street rod, ect.). They certainly build one that would work though.
Not sure about GM. They tend to discontinue stuff like that, but give them a try anyway. Even if it is NLA they may be able to contact a dealership that has an NOS one still in stock. Top dollar though.
Old Jan 12, 2004 | 01:30 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Last time I checked, you could still order the 90-92 TPI SD harness. If you order a painless harness, yes, it will work... But it doesn't come with the fender bulkhead (near the ECM) and all of the stock lengths and loom. The GM one will come with everything sized correctly and loomed just like your factory harness. It would take less IMHO to convert a SD TPI harness to MAF than to refit a painful harness as a factory harness.
Old Jan 12, 2004 | 02:49 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
On a similar point.Now that i'm gutting my engine bay and getting rid of the GM wiring for the TPI,I am looking to replce the wiring that runs from the big block next to the brake booster and runs down the drivers side chassis rail and to the headlights,headlight motors,side markers and spotlights.
Is this still available??
PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
