Running Speedo without ECM
Old Jan 16, 2004 | 03:16 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
I am having some major problems trying to get my speedo working. From what i have searched, i am seeing that i may need a buffer box for a mid 80's camaro? Is that right. But i dont have the ecm anymore, its gone, banished.. So how do i get it to work. Its a 1990 camaro, and just want to see how fast i am going!
Old Jan 17, 2004 | 10:47 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Was your car a factory TBI?
If so, you may already have the buffer box, just need to run the wires from the tranny to the box.
Here is a pic of my old buffer box,
It was behind the dash on the pass side.
Old Jan 17, 2004 | 11:37 AM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
No, it was orginally a 3.1 v-6. I cant find no buffer box anywhere under the dash. There is a little yellow box, but it doesnt look anything like that nor has that many wires running to it. Very confusing. I just need to know what i need and how to wire it up now.
Old Jan 17, 2004 | 11:47 AM
Zepher's Avatar
I believe it is 2 wires from the VSS in the tranny to the box and one wire to the speedo. the other wires went to the ECM.
There was a thread the other day that showed which wires are needed., but I don't remember the thread.
Box was in Firebirds from 86-89, at least in the Trans Am and Formula, not sure about the V6 cars.
I think 90-92 Camaros with the TBI motor also have the box.
Old Jan 17, 2004 | 05:54 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
WEll, yes, there are 2 wires. And i have my whole dash pulled apart and see no box. But there must be a box or was the box just in the ECM?? I just need to see how fast i am going! he he
Old Jan 17, 2004 | 09:01 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
IF your car had the same ecm as the '90+ tpi cars then the buffer was built into the ecm. Since you don't your ecm any more than you will probably need the yellow buffer box.
Jorlain
Aug 24, 2022 05:11 PM
Jae992
Aug 27, 2015 09:07 AM
355tpipickup
Aug 19, 2015 10:02 PM
marcusaw
Aug 10, 2015 08:13 AM
beachrodder
Aug 7, 2015 04:27 PM
