Please Help!!!! >fuel Pump
Old Jan 19, 2004 | 10:55 PM
87bird
Guest
Posts: n/a
I need to replace the fuel pump ASAP. I saw a pic a while back where someone cut a whole in the hatch area to get to the fuel pump easily and welded it back in. Can someone please post that pic if they have it. Any help will be very greatly appreciated.
-Jordan
Old Jan 22, 2004 | 06:05 PM
mace89's Avatar
Car: 89 RS
Engine: 305 v8
Transmission: 700 R4
I dont know where the pic is, but someone cut an access hole in my 89 RS. I would be very, very careful if you cut a hole. The fuel tank and sending unit lines are only about half an inch below the sheet metal. Whoever cut in my car might have also cut thru the sending unit lines, because they had all been spliced back together with rubber hose and clamps.
Old Jan 22, 2004 | 09:26 PM
apinaire's Avatar
Car: 84 berlinetta
Engine: 383
Transmission: 700-R4
why dont you just drop the fuel tank, its a whole day job but at least you dont have to cut up your car.
Old Jan 23, 2004 | 07:09 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Where you cut it, is no big deal. ain't gonna hurt anything. Unless you drill into the tank. Myself I welded every seam in my car and never thought that there was a gas tank inches away.
I would also cut my floor rather then just about remove the rear end to get at the tank, then the removal and install work is a pain if it has some gas in it still, even on a easier accessed car.
It would be better to do it slow and right. Ive taken the one in my wagon out the right way 4-5 times in a day but I do not wanna do it to my 3rd gen. Few min with the air chisel and another 20 Min's and the pump is done.
Do it clean and make a nifty access cover.
I have the pics on my computer somewhere. ill find em.
Old Jan 23, 2004 | 04:15 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I would do a better job then in the pics but you get the idea.
Old Jan 23, 2004 | 04:16 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Old Jan 23, 2004 | 05:47 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
I've done this before.
DON'T cut the floorpan 'tilll you remove the tank!!!(or you'll be replacing the tank, as well!)
Once you remove the tank you can cut an access hole about middleways and forward on the hump. A small tube cutter, short pieces of fuel line and clamps will prevent you from having to go through this nightmare again.
Form a piece of sheet metal over the hole and fasten it down using tar tape and SHORT metal screws! Next time you need to replace the pump, just pull up the carpet in the rear!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
