Heater controls
Old Jan 27, 2004 | 01:36 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
Heater controls
When I turn the heater on, all I get is front defrost no matter what setting I put it on. Even when I tried to put it on A/C. Last summer the A/C worked perfectly. What does this and how do I test parts to see what's bad?
Thanks guys
Brandon
Old Jan 27, 2004 | 08:54 PM
87PontiacBeast's Avatar
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
i have the same exact problem.
Old Jan 27, 2004 | 11:20 PM
3gc's Avatar
3gc
Car: Z28
Sounds like a vaccum problem not an electrical problem. I was just doing some research on this subject earlier today. I found both of my hvac vacumm lines melted. One of them connects to the intake for engine vaccmm, the other connects to the heater control valve. When the engine vacumm line isn't plugged in defrost is the default. So check to make sure that line is good. It's the purple line on the back on the heater controls.
Old Jan 28, 2004 | 11:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Often the switch, which controls where the vac is applied, leaks. Pull the control out; the switch in question is the one to which the vac harness attaches. If vac is present there, I assume you've found the culprit. Cured my problem anyway.
JamesC
Bubbajones_ya
Jul 6, 2024 08:32 PM
Nervous2
Oct 8, 2015 10:53 PM
Formula8r89
Sep 22, 2015 04:24 PM
BWilcox
Sep 20, 2015 12:19 PM
dbrochard
Sep 7, 2015 09:41 AM
