odd....apparently i'm hot wiring my own car
Old Jan 28, 2004 | 01:28 AM
ramair92rs's Avatar
Car: 92 rs
Transmission: AOD 700r4
well i just recently relocated the battery to the rear of the car, all wires were run with no problem everything ready to install just waiting for battery to finish charging. Well i put the battery in fully charged hook up the possitive terminal, then go to hook up the negative terminal and some sparks fly and the car starts tryin to turn over....... all this without keys in it. maybe i'm just retarded but i don't understand whats goin on there...... i checked to make sure it had a good ground and i didn't see where the possitive had grounded out anywhere...... any input would be very much appreciated........ many thanks,
chris
Old Jan 28, 2004 | 04:03 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
go back under the hood and see if your wires are touching the body. beyond that i am cluless sorry.
Old Jan 28, 2004 | 09:38 AM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Not sure what all is involved in the relocation but it sounds like you have the starter wires crossed up somehow so you are feeding power to the starter all the time.
midge54
Dec 27, 2019 04:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
penguinpanda0
Aug 15, 2015 06:45 PM
