Need help with Vats
Old Feb 13, 2004 | 08:52 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Need help with Vats
Anyone know where the vats module is located on a '95 3800 V6 Camaro? It is not where the factory manuel specifies. I have the cluster and the dash hanging but can not locate the module. Yes I do know what it looks like. The book says on the Airbag mounting bracket but it is not there. Maybe someone has done this job on a 4th gen before and could help me out?
Thanks in advance!
CALIROCZ28
Old Feb 13, 2004 | 09:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Have you looked on the passenger side air bag mounting bracket? Are you having a problem with the module or just VATS in general?
Old Feb 13, 2004 | 09:49 PM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Yes I looked on the passenger side airbag frame and it is not there. The module is faulty. I have a Tech l and have done numerous scans and it shows faulty VATS Module. I bought the car used so maybe a previous owner relocated it. I have tried to track the harness down but cannot find that either.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
