alt question
Old Feb 23, 2004 | 09:46 PM
cobrakiller1989's Avatar
alt question
what does the tan wire on the two plug altenator go to?
thanks
Old Feb 24, 2004 | 07:10 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: alt question
thanks
It goes through a resistance wire and ends up eventually at the the fuse panel inside at the fuse labeled "fan/chg". The tan wire MUST be key controlled since it it is the one that turns the alt on and off also.
Old Feb 25, 2004 | 06:36 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
turns the alternator on and off...always thought they were belt driven...
Old Feb 26, 2004 | 05:49 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It controls the action of the field winding. If the field is left on and the alt is not turning you will hear a buzz from the alt and it will cause the alt to fail, not to mention it will drain the battery. The only alts that are not key controlled are the so called single wire or self exciting units. Yes, they are belt driven but there is much more to them than that.
MustangBeater20
Oct 29, 2022 09:20 PM
Slush92RS
Sep 2, 2015 08:56 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
