Wire up an outside temp sensor to car power..
Old Feb 26, 2004 | 09:32 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Alright guys, i have one of them cheapo outside temp sensors from walmart. I hav esed 2 AAA batteries and am tired of thebattery thing. It uses 1 AAA battery at a time so how ould i wire this up to the car power so i dont blow anything up?
Thanks,
Shane
Here is the setup-
Old Feb 27, 2004 | 05:20 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
What you need to do for this is... :
# Find an always on power connection (I'm not entirely familiar with the specific wiring on these cars yet....)
# Connect a 1A fuse to it then run the wire through to where you need the power.
# Wire in a 1.5V regulator, with a couple of capacitors on either side of the regulator.
# Ideally between the fuse and the regulator you would want to put a filter circuit.
# Wire it through to where you have the temp sensor.
How are you placed for getting these parts and wiring them up?
Si. :lala:
Old Feb 28, 2004 | 09:03 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok.....
I have no idea where to get this stuff. Could you please tell me? Will i be able to goto radio shack for this or what?
Thanks,
Shane
Old Mar 1, 2004 | 04:46 AM
iroc-si's Avatar
I can't entirely help you there as I'm in a different country!
However unless someone else knows different, I'd start at radio shack.
Si.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
penguinpanda0
Aug 15, 2015 06:45 PM
