need help, engine wont start when aftermarket tach hooked up
Old Feb 29, 2004 | 12:16 PM
90vertcamaro's Avatar
Car: 1990 Camaro RS convertible
Engine: 305 TBI
Transmission: 700-r4
ok, here is my problem, when i have it hooked up, the engine wont start, when it's not hooked up the engine starts and runs just fine, when the engine is running and i touch the wire to the tach lead the engine dies. my dad says i have a short somewhere. i have no clue what the problem is...P.S. i'm installing this aftermarket tach cuz the in dash tach doesnt work anymore
Old Feb 29, 2004 | 04:25 PM
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
sounds like you are grounding out the ignition. check all the wires you ran for the tach for shorts.
Old Feb 29, 2004 | 04:39 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You have a short somewhere. What color wire are you trying to hook up to the tach lead? Green or white?
Old Feb 29, 2004 | 05:02 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
You must have a short somewhere like everyone else said. You gotta trace your tach wire & find out where. What happened to me one time was I uncovered some of the sheathing(is that how you spell it???) on the wire while going through the firewall. Hope you can solve it
Old Mar 3, 2004 | 03:15 PM
Engine: 305 TBI
i got the red going to battery, black to ground, white to swtiched lights and green to negative coil terminal, i'm fairly certain that there arent any shorts in the wiring cuz i soldered and heat shrinked all of my conections
Old Mar 3, 2004 | 06:40 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
are you running green all the way to the coil?
if yes, your tach is bad, if no, try it
Old Mar 4, 2004 | 01:56 PM
Engine: 305 TBI
i got the tach from a friends V6 camaro, i know that there are different setings for the I4, V6, and V8, the was a orange wire and a brown wire, and they were cut, my friend said those two wires should be reconnected for the V8 setting, how should they be?
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
