oil pressure sender/ fuel pump problem
Old Mar 2, 2004 | 08:41 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
The weather pack connector that goes to my oil pressure sender(above the oil filter) has the tang broken off it from age and it vibrates out sometimes. This causes my fuel pump to stop and my car shuts off once the carb runs out of gas. My question is should I bypass it and just connect the fuel pump leads togther?, or should I get a new weather pack connector? That sounds like the better solution to me, but does anyone know where I can get one from?
Old Mar 2, 2004 | 09:31 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go to a junkyard or sometimes the pepboys has them in stock.
Old Mar 3, 2004 | 04:55 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If you have a guage the AC Delco plug part # is PT 121. That is for 3 wire systems that use a fuel pump switch in the oil sender. I use a place on the net called expressparts. The Pep knockoffs don't hold up well under temp.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
