Fuse takes a while to burn but eventually go out.
Old Mar 10, 2004 | 10:25 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
What would cause an accessory fuse to work for like 3 months, then burn and when I replace it it works for another 3 months then burns, and now burns like every three days?
Heres some things I though it might be:
Loose wire that intermitantly touches metal
Voltage regulator
need help very annoying thanks
Old Mar 11, 2004 | 05:41 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
What does the fuse feed?
Old Mar 11, 2004 | 08:39 AM
GASGZLR's Avatar
It feeds the radio and accesories like the dome light and cigarette lighter
Old Mar 11, 2004 | 09:39 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Its probably the loose wire. If you have powerdoors and power windows id start with the wires from the door to the body and spread out from there.
Old Mar 11, 2004 | 10:07 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Our cars have probs with the cigarette lighter. Try seeing if that is the problem. Maybe its shorting out there. Just a thought.
Old Mar 12, 2004 | 09:57 AM
GASGZLR's Avatar
Thank for the replies I'll have to check that stuff out.
Could it be the voltage regulator, cause one of my friends said it could be going out and sending spkies of current through the system. I know the regulator is in the alternator could it cause this? I have never heard of it doing that.
Old Mar 12, 2004 | 01:38 PM
3gc's Avatar
3gc
Car: Z28
From what i understand about electronics it can't send out current unless there is something drawing it.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
GTAman
Mar 15, 2019 11:40 AM
Cameeeero
Sep 18, 2015 04:00 PM
tero
Aug 15, 2015 02:47 PM
