EGR relay
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
EGR relay
Is there an electrical relay (or sensor) that controls the EGR?
If so, can someone please describe where it is located under the hood (there are alot of relays under there)?
Thank you!
Thank you!
Re: EGR relay
Thank you!
Thank you!
Sorry... I forgot to add that I recently replaced the EGR Valve, Harness, and Solenoid.
But I still get a code 32 sometimes when the car is cold.
Since I'm running out of things to replace, I didn't know if there was an electrical relay or another sensor I should check?
Thanks again.
Thanks again.
