fuel guage problem
Old Mar 21, 2004 | 09:40 PM
86whitetransam's Avatar
Car: 1986 Trans Am
Transmission: 700r4 auto
fuel guage problem
i was wondering if anyone had a idea as to what my problem is my fuel guage stays at full it started like a month ago when i was screwing around doing a burn out and it caught on and it did it then i took the fuse panel off and just moved things and it started to work again well it happend again the other day while i was doing a burn out and i cant get it to work again this time any ideas
thanks
i have a 86 trans am with a 305 tpi if that helps at all
Old Mar 23, 2004 | 08:49 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
your probably grounding out a wire above the rear axel that goes to your gas tank. climb under there and tape up that wire.
Old Mar 23, 2004 | 08:53 PM
Car: 1986 Trans Am
but that dont explain why when it did it the first time and i screwed with stuff in the fuse box it fixed the problem. but i will give it a try this weekend. if anyone else has any imput i could really use it. thanks
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
92camaroJoe
Aug 13, 2015 06:07 AM
