Bad window motors or bad switches?
Old Mar 23, 2004 | 01:29 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Hey guys,
I was in my car the other day and I went to roll down the window and it wouldn't move at first. Then I noticed it only went down when I had the switch pushed down almost all the way, but not quite. When I would put the switch all the way down, it would stop. Does that sound like a problem in the switches or in the motors? I'm looking at replacing the motors anyway, but I might as well get switches too if I need them. Thanks in advance.
Old Mar 23, 2004 | 08:42 PM
tstokka's Avatar
Car: 2- 1986 TA 1 t-top 1 hardtop
Engine: 305s
Transmission: autos
sounds like switches to me. unless the connector is about to fall off on the back side of the switch
Old Mar 24, 2004 | 10:12 AM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
hey man i had the same problem which i managed to fix.....
First off its probably not your switch.....which was a big mistake for me
I ripped apart my door pannel (drivers side casue thats where the problem was) and to my surprise the 2 wires going to the windo motor had the insulation off and grounding out on the door frame!! so i was like ****ty.....so i taped them up and now it all works awsome.....i doubt its the switch cause thats what i first thought but found even when i used the switch for the passengers side for the drivers side (i switched it) the window still didnt work.......but yeah man check for some insulation rubbing off:lala:
Old Mar 24, 2004 | 07:27 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
swtiches, mine do it also.
My head light switch does it too. For the longest time i thought my head light motors were burn out. Till one day i pressed the switch a little and they popped up.
Old Mar 25, 2004 | 12:40 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Does the other switch work normally? If so, try swapping it with the suspected faulty one.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
pfsteichen
Feb 9, 2016 06:59 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
