gauge cluster not working w/ headlights on
Old Mar 24, 2004 | 11:51 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
the gauge cluster works fine in the day but the moment i turn the headlights on, the dashlights do not work, all the gauges except the speedo stop working and both blinker lights are stuck on.
what is going on?
Old Mar 25, 2004 | 12:21 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Sounds like a bad ground somewhere. Maybe you tore the circuit board without realizing it?
Or, maybe it's just not quite in place; you can try loosening the cluster and adjusting it to see if it hits a spot where everything works.
Old Mar 25, 2004 | 12:23 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i dont think i tore the circuit board, otherwise it would never work.
but it only stops working when my headlights come on.
i already unscrewed the panel, moved it a bit and bolted it back up, no good. im gonna check where all the wires plug into it now and see if that helps, but please, more suggestions are needed, cuz if this isnt an easy fix, im going straight to the mechanic.
Old Mar 25, 2004 | 12:58 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok problem fixed, i got back under, pushed all connections in a lil bit, found a plug that wasnt plugged into anything (had the 4x2 socket layout, all but one had a connector) i could not find where it plugged in so it stayed unpluged, i also jiggled the fuse box.
it works now but im curious where that plug goes lol
tyeo098
Nov 30, 2015 06:27 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Eric-86sc
Sep 28, 2015 11:37 AM
codeysabatini
Sep 20, 2015 11:36 AM
andy74
Sep 3, 2015 08:41 AM
