Remote coil
Old Mar 25, 2004 | 04:35 AM
jrod's Avatar
Car: 87 Camaro
Engine: 305 4 BBL
Remote coil
I have an 87 Camaro w/ 305 4bbl (grocery getter) that the motor has been out of for a few years, thanks to the wife.
I picked up a motor from a friend and dropped it in last weekend. The new motor had an EFI distributor ( coil in cap) the old motor had a remote coil dist. So I swapped them out to accomedate the existing wiring harness conections. All seems fine, the dist. is installed in the correct posistion, plug wires connected in proper order yada yada.... But no spark to plugs. OK here is my question, The remote coil has two plug in ports ( not counting coil wire ) I can only find one plug that fits, the same for the distributor. Can anyone tell me if these two ports, one on the coil and one on the dist., are supposed to be open or did I miss something
Thanks very much for any and all help !
John R
Old Oct 5, 2007 | 10:23 AM
svroom's Avatar
Re: Remote coil
Did you ever get this solved? I have the same setup 88 TPI, and found that the TPI Air Intake temperature sensor fits into the other connection. I couldn't remember where it went, but now I don't get any spark and can't figure out why. This is the first start try after the engine swap.
Skip
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
RedLeader289
Sep 23, 2015 06:50 AM
