help!
Old Apr 2, 2004 | 04:40 PM
87CamaroIroc's Avatar
Car: 1987 Camaro IROC
help!
what does it mean when my oil light comes on?!?
Old Apr 3, 2004 | 07:07 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The sensor senses low oil pressure. I wouldnt drive it very far like that.
Old Apr 3, 2004 | 07:24 AM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Get yourself a oil pressure gauge and hook it up in place of the stock pressure sending unit. It's a gold can on the driver's side of the distributor.
Start the car and see what it reads. If you're reading around 30-40psi, you're fine and the sending unit needs to be replaced. If you're reading really low, you might have to replace the oil pump.
Old Apr 3, 2004 | 09:09 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
take heed or youll blow the engine. not pretty, i did that on my 88 GTA. i wish i had an oil light on that
