yet another headlight problem from yet another T/A
Old Apr 7, 2004 | 01:10 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
My headlights don't come up on my 82 T/A... I have to use the ***** to crank them up. I hit the switch, nothing. no noise, no sound at all. I'm thinking it's an electrical problem... where do i start first? the relays? the lights come one, but the assemblies just don't move. I figure, I'll grab some new relays, and then plug them in and see if they work. what should I expect? this is my first F-body, and third gen car. it sat out for a while before i got it, and I'm slowly but surely building the car. I just got the car to crank and run today. I have some more tweaking left to do, and just wanted to knock out another bug.
Old Apr 7, 2004 | 08:37 AM
87PontiacBeast's Avatar
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
did u check the fuses?
Old Apr 7, 2004 | 04:32 PM
Car: 1982 Trans Am
Engine: 383 chevy
dumbass question..... where are they? i looked in the main block under the driver's side panel...... didn't even see a spot for them.
Old Apr 7, 2004 | 07:28 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
unlpug the motors( you can get to the plugs from underneath) and check the voltage while someone switches them on and off.
that will tell you for sure. if you dont trace the wire back till you do.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
