Light bult holders.
Old Apr 12, 2004 | 07:01 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Light bult holders.
Does anyone know what the part numbers are for the bulb holders on the back of the gauge cluster? I am missing quite a few of them for some reason and I am hoping to replace them while I am working on my gauge cluster.
Old Apr 12, 2004 | 07:52 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The ones that you can replace the bulbs in are "ED 22". The ones with the non-replaceable bulbs are "PC161", PC168", and "PC194"
Old Apr 12, 2004 | 08:21 PM
Car: 1987 IROC Z
IM not sure I follow you about those that are replaceable and those that arent. Perhaps I should look at it before asking this question (im still at the office). They are not expensive I hope. Which is which? I remember seeing green plugs, and black plugs.
Old Apr 12, 2004 | 08:32 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What I am talking about is that some of the early models had sockets that if a bulb burned out, you just pulled the bulb out of the socket and put another one in. In later models, they were designed to replace the bulb and socket as a unit. In other words, the socket is not re-usable and has the words "REPLACE ENTIRE UNIT" on the base. The PC161's sockets are black, PC168's are blue, and PC194's are gray. The ED 22 sockets are green and bulbs can be replaced in them.
Old Apr 12, 2004 | 08:44 PM
Car: 1987 IROC Z
well damn, aint that about a biyach
Old Apr 12, 2004 | 08:49 PM
Car: 1987 IROC Z
I don't suppose you know the part number for the PCB "tape" on the back of the console?
Old Apr 12, 2004 | 08:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can find the empty sockets in some auto parts stores, they come two to a pack. I went to a couple of the local junkyards and picked some up for a few bucks. BTW, the old style sockets are completely interchangable with the new style. No I don't know the part number for the PCB tape, but I can find out tomorrow when I visit my local source of recycled components. Also, I forgot to mention that you might have some missing because the system they went to in your car is not being used. Like the shift light, the choke light.
Old Apr 13, 2004 | 03:55 AM
Car: 1987 IROC Z
Alright... this is what I see on the console...
For the lights, their is a variety of black and green sockets (and one blue socket in the left corner... the PCB has various numbers on it. Not sure which would be the part number though.
25081S05
or
6954-1
7065 14
Its a 140mph speedo.... any info ?
Old Apr 13, 2004 | 07:39 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What year and model is your car>
Old Apr 13, 2004 | 11:05 AM
Car: 1987 IROC Z
87 IROC, 350 TPI...
Old Apr 13, 2004 | 03:06 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Okay,
I have some good news and some bad news for you. The good news is that the part number for the PCB tape is 2504 5480 (the number was changed by GM). The bad news is that it has been discontinued and is no longer available. Time to hit the junkyards if you need one. If your light bulb sockets do not have "REPLACE ENTIRE UNIT" on the base of them in white letters, then you can just pull the old light bulb out and put a new one in and press on about your business.
Old Apr 13, 2004 | 03:56 PM
Car: 1987 IROC Z
A bummer that truly is, but not surprising though at the same rate. The break in the PCB is small, so I am going to try to fabricate a better solution for it. I live in a desert town and although thirdgens are more than plentiful in junkyards, most of them have been sitting their for an excessive amount of time and are probably in worse condition. Wasn't their a tech article about this ?
Did your reference say whether or not the little bulb holders were still available ?
I appreciate all the time and effort you put into finding this information for me trickster...
Old Apr 13, 2004 | 04:38 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
They are still available through some auto parts stores. However, I would just go to a junkyard and pull some out of a junker. A little cleaning with a toothbrush and they are good to go. The same goes for the PCB tape. Take one out and lightly use a toothbrush on it to remove the heavy stuff and then use a soft cloth to wipe it down with isophrophyl alcohol.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
