90-92 Firebird switch lights
Old Apr 25, 2004 | 02:48 AM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
The 90-92 Birds used tiny red LED's to illuminate the hatch/defrost/fog light switch bank.. One of mine is burned out and another starting to go.. It's flickering.
Does anyone know where you can pick up these LED's ? They're tiny.. about 1/8 inch..
The dealer doesn't have them...
Old Sep 13, 2004 | 11:40 PM
Rob91GTA's Avatar
Car: 91 GTA
Engine: 5.0 TPI LB9
Transmission: 700R4 Auto
ttt
I thought I would bring this to the top again cause it is a good question. A couple of these swich lights are burnt out on mine too. No luck at the pontiac dealer. I purchased some assorted LED's at Radio Shack but they only burnt right out. They couldn't handle the volts/watts. Some kind of electronics place should have them. But we don't know exactly what the specs should be for the LED's. Anyone have any opinions on this???
Old Sep 14, 2004 | 12:07 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If the LED's will physically fit into the housing, all you would need to add would be the proper resistor. About 680 ohms will be sufficient for all colors.
Oh yeah, and the T1 size LED is 3mm or very close to 1/8" in diameter.
Old Sep 15, 2004 | 02:35 AM
Morley's Avatar
Go to a junkyard and scarf up all of the lighted switches you can find and use the LED's from them.
BRoss99
Aug 10, 2025 05:08 PM
The_Phoenix
Feb 4, 2016 07:10 AM
355sbcTPI
Aug 19, 2015 04:38 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
