A hatch release question not yet coverd (can it be true?)
Old Apr 25, 2004 | 04:12 PM
hammy's Avatar
Car: 91 Firebird
Engine: 3.1
Transmission: auto
I have searched and searched and have had no luck with this one. I am installing an alarm that also has a hatch release on my 92 v6 (not that it matters) Bird. Everything works great but the hatch release. All items that I can find lead me to connect to the black wire at the rear of the hatch release switch with a neg pulse. I have tried and it will not release. During the install I went so war as to cut the wire to make sure I had a good connection by striping wires rather than using a tap connecter. With the black wire cut the hatch will still open with the button on the dash. This leads me to believe that I may want to look at the other 3 wires. I have found that if you connect the brown and black wires (after removing the switch) the hatch will pop but I am unsure of what may happen if I just put a relay between the 2. If someone has a list of the 4 wires and were they go and an idea of the switch operation please post it so I can take a look. It is raining today so harder to spend time outside trying to trace wiring. Any other sug. Would be great
O the alarm is a chrimestoper 2000 III with the addition of a proximity sensor
Old Apr 26, 2004 | 01:40 AM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
a relay would work, just get a simple 12v relay, connect the 30 and 87 terminals to the brown and black wires( the ones that go to the switch) and then 1 of the coil terminals to a constant 12v source, other terminal to your hatch release output on your alarm, if it is a negitave output that is, if it is positive output, just swap it around, constant ground, pulsed positive
Old Apr 26, 2004 | 07:38 AM
hammy's Avatar
Car: 91 Firebird
Engine: 3.1
Transmission: auto
Cool I will give it a shot and let everyone know. Im sure it will work Just was wanting to know why ther are 4 wires to open 1 hatch
Old Apr 26, 2004 | 07:45 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have a convertible, so i didnt have a stock hatch (trunk really) release...
the one i got was from a car in the junkyard.. it had only one wire going to the 'noid.. and a short wire that let you ground the lock to the chassis..
when you hit the button, its just like if you turned the key.
Old Apr 26, 2004 | 11:02 AM
hammy's Avatar
Car: 91 Firebird
Engine: 3.1
Transmission: auto
all better i put the relay in place and got it up in the dash no problem and it all works! Just had to run down to the fuse block for always on + but thats no big deall thanks for the help!
Old Apr 26, 2004 | 12:04 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
no problem, thats what were all here for to help each other
MustangBeater20
Oct 29, 2022 09:20 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
