uh oh, no blinkers
Old Apr 27, 2004 | 11:21 PM
92formula305tbi's Avatar
uh oh, no blinkers
I have a 92 formula and the blinkers don't work but the hazards do. There is a seperate fuse for the blinkers than the haz but they are both good, any ideas?
Old Apr 28, 2004 | 12:05 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i had the same problem, i suck at explaining stuff in text, but if you bare with me, let me try.
pull out the black panel that sits above your pedals, the same panel that your fuse panel is part of.
on the passenger side of the steering column, their is a a group of wires that connect into a socket. check and make sure that is secured.
this connection is strapped to the steering column so you cant really miss it.
that was my problem, i wouldnt have a blinker, it would stay lit, but if i kicked under my steering column, it sometime worked.
my hazards always worked.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
