V6-v8 swap won't start.
Old Apr 28, 2004 | 01:23 PM
jderen's Avatar
I just switched an 87 350 tpi into my 90 rs and I am having some starting problems. When I turn the key the engine turnes over, the fuel pump turns on, and the plug wires spark intermittently. Sometimes I try it and the plug wires spark, sometimes they do not. When the wires do spark sometimes it sounds as though it is about to start, aka fires for a moment, and other times it sounds as if only 1 cylinder is firing.
I am also setting a code 46 in the computer and showing a security light.
I am getting proper voltage from the ignition lock and the key reader.
Please help.
Thanks,
Joe
AussiePr0nCar
Mar 6, 2020 04:04 PM
theshackle
Mar 5, 2017 06:37 PM
E Rod
Aug 28, 2015 05:17 AM
djmarch
Aug 19, 2015 12:07 PM
86Base
Aug 8, 2015 01:34 PM
