no knock detected
Old May 1, 2004 | 07:05 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
no knock detected
me and a friend replaced the intake gaskets and after that my car had all sorts of knock. it will give about 5 counts in 1st, here and there knock in 2nd and consistant knock in third . this happens when im firmly in the gas and between 3-400 rpm. i replaced the knock sensor, plug, o2, ESC,.
we put the car on ramps and tapped next to teh knock sensor with no results. all of this was done using diacom. my timing was set at 6' per the sticker. is there something i over looked?
we checked the plug for power and its got power and ground.
how do i go about testing the other terminals in the plug going to the ESC?
i cant drop my motor in until i figure out WHY it has knock from the intake gasket replacement and why its not detecting knock.
Old May 1, 2004 | 11:24 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
If you're using the stock damper, don't discount the fact the outer inertia ring may have spun a little. My beater shows 2°atdc timing when, after remarking TDC on the damper, it's (roughly) 4°btdc. I set it to 2° (stock is 0) to avoid knock running 87oct.
Old May 2, 2004 | 04:03 AM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i gave that consideration but this happend IMMIDIATELY after we replaced the intake gaskets. one of my friends is saying its a ground issue in the D terminal on the plug possibly. he said loss of ground at the esc module would cause a high signal. That would lead to excessive knock which is whats going on with me.
what im thinking is the moving of the harness caused a brake in the wire ir it rubbed and chaffed which caused a break during the gasket replacement.
he posted earlier and mentioned this. being he is a GM tech in training and is a thirdgenner helps greatly.
im gonna see if me him and another bird brothern can get together and fix this issue sometime this week. and luckily for us we all have factory helm manuals!!!
as for teh balancer, im looking into a TCI rattler. being i work at comp i get a wicked discount .
Old May 2, 2004 | 10:12 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
did you check out all the cars friday that were down for the pump gas drags?
I was down there , probably saw you
Old May 2, 2004 | 06:59 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
ohhh yea i was there. the staging area was infront of shipping which is my dept. i went out there on my breaks and looked around. i was gonna go see the runs that eve but was doing diacom runs trying to see if my new ESC fixed my knock issue. i was wearing a white comp shirt with long hair.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
BWilcox
Sep 20, 2015 12:19 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
