Power Door Locks Almost Work
Old May 3, 2004 | 02:30 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
If the power door locks try to operate, but don't seem to pull hard enough to unlock or lock the doors, where and what could be the problem? I push the buttons, and they all work. The locks sound like they've operated, but they never do. I can sit and watch the lock button, and it just will barely move, as if the motor isn't strong enough to do it's job.
Trickster? Anyone? :rockon: A pre-emptive you rock .... thanks
Old May 3, 2004 | 04:19 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I fixed mine.
I lubed up the assembly on the inside of the door with silicone lube.
If you pull off the door panel, you can see where the locking motor is as well as the rods and the mechanical assembly. I just lubed up all the moving parts in the assembly and now both door locks work perfect.
Old May 5, 2004 | 06:30 PM
Big_C's Avatar
Car: 1989 Firebird
Engine: Custom 355 V8
Transmission: TH-350 with 3000 converter
I had the same problem on my 1989 firebird. All I had to do was rip off the door pannell, then I sprayed the lock mechanism and solinoid with WD-40. Then I manually locked and unlocked the door, and after this the door lock worked fine.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
