front right blinkers
Old May 6, 2004 | 04:16 PM
91Z28-350's Avatar
Hi all,
I'm having a problem with my 1991 Z28.
1) All lights turn on when I hit my hazards including the dash.
2) When I hit the turn signal switch, the flasher switch (near the fuse box) toggles audibly. The rear right turn signal flashes, but the dash light and the front right side marker and front right signal under the head lights don't flash.
Are they wired separately? Where would be a good place to start? I don't believe the problem is in the switch itself. It seems there is a loose wire between the flasher switch and the dash and front turn signals. Do those run off the flasher switch near the fuse box? There are 2 blue wires coming off of it, one thick, one thin. Which is which?
Thanks,
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Jk_Under
Sep 2, 2015 10:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
