power windows
Old May 11, 2004 | 03:13 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
power windows
anyone ever hooked up there power windows to constant power instead of ignition? and was there any problems with doing that?
hate needing the keys just to move the windows
Old May 12, 2004 | 01:47 PM
goofnrox's Avatar
Other than a slight security problem, its as easy as switching the power source. Just be sure it gets an inline circuit breaker or fuse. This is an especialy useful feature when its about to rain, and you don't have your keys with you.
Old May 16, 2004 | 08:33 AM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
I do this mod to all of my cars. (Would-bd theives don't know I do this, and besides, they'd have to disable the alarms first...)
First, find the power window breaker in your fusebox. Remove it and meter the sockets that it sits in. Find the terminal that DOES NOT have +12 voltage on it when you turn the key to RUN.
Now, find a different terminal that has +12 power on it at all times.
If you don't care about stock, you can solder wires directly to the breaker, and terminate them in 1/4" spade tabs, for easy installation into your fusebox. If you want, you can put 1/4" spade sockets onto the other end of the wire, and plug them into the breaker directly.
If you need pics, let me know and I'll go out and take some.
Old May 16, 2004 | 10:58 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yes - Picks please! This sounds like a good mod.....
Old May 16, 2004 | 11:17 AM
dr1's Avatar
dr1
Engine: 305 TBI
yeah i thought about hooking it upto a relay with the alarm, is that what you did with yours?
Old May 18, 2004 | 06:45 PM
The black & white wires go to the original breaker, which is now taped up to prevent shorting. This fuse panel is from a 1986 Special Edition.
Old May 19, 2004 | 09:58 AM
vernw's Avatar
Thanks for th picture and explanation, I think I'm going to have to give that idea a try!
Again, THANKS!!!!
- Vern
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
